[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/error.c |no clones | 0 monsters | 0 warnings
Sat Mar 3 21:03:28 EST 2007
Hello glynn,
ANALYSIS
lib/gis/error.c functions
G_message (Begins at: 82 Ends at: 92)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
G_fatal_error (Begins at: 94 Ends at: 108)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
G_warning (Begins at: 110 Ends at: 123)
LOC:          |      14 |       |      OK |
metrics are OK
G_suppress_warnings (Begins at: 125 Ends at: 132)
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
G_sleep_on_error (Begins at: 134 Ends at: 141)
LOC:          |       8 |       |      OK |
metrics are OK
G_set_error_routine (Begins at: 143 Ends at: 147)
LOC:          |       5 |       |      OK |
metrics are OK
G_unset_error_routine (Begins at: 149 Ends at: 154)
ParamNBR:     |       0 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
print_error (Begins at: 157 Ends at: 211)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
log_error (Begins at: 213 Ends at: 248)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
write_error (Begins at: 250 Ends at: 282)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      14 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
mail_msg (Begins at: 284 Ends at: 302)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
print_word (Begins at: 305 Ends at: 356)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
LOC:          |      52 |       |      OK |
metrics are OK
print_sentence (Begins at: 359 Ends at: 395)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      37 |       |      OK |
metrics are OK
G_info_format (Begins at: 397 Ends at: 412)
CalledNBR:    |       2 |       |      OK |
LOC:          |      16 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
