[GRASS-QA] GRASS QA: glynn | ./grass6/lib/gis/closecell.c |no clones | 0 monsters | 3 warnings
Sat Mar 3 23:50:21 EST 2007
Hello glynn,
ANALYSIS
lib/gis/closecell.c functions
G_close_cell (Begins at: 77 Ends at: 108)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
G_unopen_cell (Begins at: 110 Ends at: 120)
LOC:          |      11 |       |      OK |
metrics are OK
close_old (Begins at: 122 Ends at: 156)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
close_new (Begins at: 158 Ends at: 394)
Complexity:   |      30 |    ** | Warning |
CalledNBR:    |      79 |    ** | Warning |
LOC:          |     237 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
G__write_fp_format (Begins at: 397 Ends at: 429)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-03 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
