[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |no clones
| 2 monsters | 6 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Mar 5 20:59:33 EST 2007
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 160 Ends at: 181)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_define_flag (Begins at: 184 Ends at: 242)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 59 | | OK |
metrics are OK
G_define_option (Begins at: 245 Ends at: 316)
LOC: | 72 | | OK |
metrics are OK
G_define_standard_option (Begins at: 319 Ends at: 542)
Complexity: | 26 | ** | Warning |
CalledNBR: | 29 | | OK |
LOC: | 224 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 545 Ends at: 597)
CalledNBR: | 1 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_parser (Begins at: 599 Ends at: 864)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 266 | *** | MONSTER |
1 metric are OUT OF RANGE!
uses_new_gisprompt (Begins at: 867 Ends at: 917)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 51 | | OK |
metrics are OK
G_usage (Begins at: 919 Ends at: 1102)
Complexity: | 31 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 184 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1104 Ends at: 1120)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 1122 Ends at: 1326)
CalledNBR: | 65 | ** | Warning |
LOC: | 205 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1328 Ends at: 1559)
Complexity: | 41 | *** | MONSTER |
CalledNBR: | 80 | ** | Warning |
LOC: | 232 | ** | Warning |
G_script (Begins at: 1561 Ends at: 1655)
Complexity: | 22 | * | |
CalledNBR: | 27 | | OK |
LOC: | 95 | | OK |
metrics are OK
generate_tcl (Begins at: 1657 Ends at: 1742)
Complexity: | 10 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 86 | | OK |
metrics are OK
G_gui (Begins at: 1745 Ends at: 1774)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_tcltk (Begins at: 1777 Ends at: 1792)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1794 Ends at: 1823)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1825 Ends at: 1838)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1840 Ends at: 1867)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1872 Ends at: 1881)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1883 Ends at: 1943)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1945 Ends at: 1982)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1984 Ends at: 2026)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 2028 Ends at: 2094)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 2096 Ends at: 2136)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 2138 Ends at: 2165)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2167 Ends at: 2190)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2192 Ends at: 2255)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2257 Ends at: 2295)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2298 Ends at: 2354)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2356 Ends at: 2384)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2386 Ends at: 2394)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2396 Ends at: 2486)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2488 Ends at: 2518)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2520 Ends at: 2577)
CalledNBR: | 20 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_recreate_command (Begins at: 2579 Ends at: 2681)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-05 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
