[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/parser.c |1 clones
( parser.c )| 2 monsters | 6 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 03:34:43 EST 2007
Hello martinl,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 160 Ends at: 181)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_define_flag (Begins at: 184 Ends at: 242)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 59 | | OK |
metrics are OK
G_define_option (Begins at: 245 Ends at: 327)
LOC: | 83 | | OK |
metrics are OK
G_define_standard_option (Begins at: 330 Ends at: 553)
Complexity: | 26 | ** | Warning |
CalledNBR: | 29 | | OK |
LOC: | 224 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 556 Ends at: 608)
CalledNBR: | 1 | | OK |
LOC: | 53 | | OK |
metrics are OK
G_parser (Begins at: 610 Ends at: 875)
Complexity: | 37 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 74 | ** | Warning |
LOC: | 266 | *** | MONSTER |
1 metric are OUT OF RANGE!
uses_new_gisprompt (Begins at: 878 Ends at: 928)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 51 | | OK |
metrics are OK
G_usage (Begins at: 930 Ends at: 1113)
Complexity: | 31 | ** | Warning |
CalledNBR: | 53 | * | |
LOC: | 184 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1115 Ends at: 1131)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 1133 Ends at: 1337)
CalledNBR: | 65 | ** | Warning |
LOC: | 205 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1339 Ends at: 1570)
Complexity: | 41 | *** | MONSTER |
CalledNBR: | 80 | ** | Warning |
LOC: | 232 | ** | Warning |
G_script (Begins at: 1572 Ends at: 1666)
Complexity: | 22 | * | |
CalledNBR: | 27 | | OK |
LOC: | 95 | | OK |
metrics are OK
generate_tcl (Begins at: 1668 Ends at: 1753)
Complexity: | 10 | | OK |
CalledNBR: | 33 | | OK |
LOC: | 86 | | OK |
metrics are OK
G_gui (Begins at: 1756 Ends at: 1785)
CalledNBR: | 8 | | OK |
LOC: | 30 | | OK |
metrics are OK
G_tcltk (Begins at: 1788 Ends at: 1803)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1805 Ends at: 1834)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1836 Ends at: 1849)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1851 Ends at: 1878)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1883 Ends at: 1892)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1894 Ends at: 1954)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1956 Ends at: 1993)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1995 Ends at: 2037)
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 2039 Ends at: 2105)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 2107 Ends at: 2147)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 2149 Ends at: 2176)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 2178 Ends at: 2201)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 2203 Ends at: 2266)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2268 Ends at: 2306)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2309 Ends at: 2365)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2367 Ends at: 2395)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2397 Ends at: 2405)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2407 Ends at: 2497)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2499 Ends at: 2529)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2531 Ends at: 2588)
CalledNBR: | 20 | | OK |
LOC: | 58 | | OK |
metrics are OK
G_recreate_command (Begins at: 2590 Ends at: 2692)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
