[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/main.c |no clones | 0 monsters | 0 warnings
Tue Mar 6 16:58:12 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/main.c functions
main (Begins at: 17 Ends at: 114)
Complexity:   |       5 |       |      OK |
CalledNBR:    |      43 |     * |         |
LOC:          |      98 |       |      OK |
metrics are OK
quit (Begins at: 116 Ends at: 123)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
error (Begins at: 125 Ends at: 153)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      15 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
check_files (Begins at: 156 Ends at: 220)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      36 |     * |         |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-06 are:
                           | quartile  | limit   |
CalledNBR:              10 |        60 |      86 |
LOC:                    42 |       190 |     265 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
