[GRASS-QA] GRASS QA: brad | ./grass6/imagery/i.class/signature.c |1
clones ( cellhd.c curses.c driver.c signature.c )| 0 monsters
| 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 6 16:58:13 EST 2007
Hello brad,
ANALYSIS
imagery/i.class/signature.c functions
init_sig_routines (Begins at: 38 Ends at: 57)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 20 | | OK |
metrics are OK
prepare_signature (Begins at: 64 Ends at: 156)
Complexity: | 10 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 93 | | OK |
metrics are OK
show_signature (Begins at: 172 Ends at: 244)
Complexity: | 8 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 73 | | OK |
metrics are OK
done (Begins at: 246 Ends at: 249)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
display_signature (Begins at: 254 Ends at: 314)
Complexity: | 6 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 61 | | OK |
metrics are OK
have_signature (Begins at: 322 Ends at: 325)
LOC: | 4 | | OK |
metrics are OK
save_signature (Begins at: 333 Ends at: 347)
CalledNBR: | 2 | | OK |
LOC: | 15 | | OK |
metrics are OK
yes_save (Begins at: 349 Ends at: 376)
CalledNBR: | 6 | | OK |
LOC: | 28 | | OK |
metrics are OK
dont_save (Begins at: 379 Ends at: 382)
LOC: | 4 | | OK |
metrics are OK
write_signatures (Begins at: 389 Ends at: 398)
CalledNBR: | 5 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
write_signatures
In imagery/i.class/signature.c clones of write_signatures are:
display/d.rast.edit/edit.c use_mouse
Threshold GRASS6 key metrics values at 2007-03-06 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 10 | 60 | 86 |
LOC: 42 | 190 | 265 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
