[GRASS-QA] GRASS QA: hamish | ./grass6/lib/gis/parser.c |1 clones ( parser.c )| 1 monsters | 9 warnings
Wed Mar 7 23:55:32 EST 2007
Hello hamish,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 160 Ends at: 181)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_define_flag (Begins at: 184 Ends at: 242)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
G_define_option (Begins at: 245 Ends at: 327)
LOC:          |      83 |       |      OK |
metrics are OK
G_define_standard_option (Begins at: 330 Ends at: 553)
Complexity:   |      26 |    ** | Warning |
CalledNBR:    |      29 |       |      OK |
LOC:          |     224 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_define_module (Begins at: 556 Ends at: 608)
CalledNBR:    |       1 |       |      OK |
LOC:          |      53 |       |      OK |
metrics are OK
G_parser (Begins at: 610 Ends at: 875)
Complexity:   |      37 |   *** | MONSTER |
CalledNBR:    |      74 |    ** | Warning |
LOC:          |     266 |    ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 878 Ends at: 928)
Complexity:   |       5 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      51 |       |      OK |
metrics are OK
G_usage (Begins at: 930 Ends at: 1113)
Complexity:   |      31 |    ** | Warning |
CalledNBR:    |      53 |     * |         |
LOC:          |     184 |     * |         |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1115 Ends at: 1131)
Complexity:   |       6 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
G_usage_xml (Begins at: 1133 Ends at: 1337)
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     205 |    ** | Warning |
G_usage_html (Begins at: 1339 Ends at: 1570)
Complexity:   |      41 |   *** | MONSTER |
CalledNBR:    |      80 |    ** | Warning |
LOC:          |     232 |    ** | Warning |
1 metric are OUT OF RANGE!
G_script (Begins at: 1572 Ends at: 1666)
Complexity:   |      22 |     * |         |
CalledNBR:    |      27 |       |      OK |
LOC:          |      95 |       |      OK |
metrics are OK
generate_tcl (Begins at: 1668 Ends at: 1753)
Complexity:   |      10 |       |      OK |
CalledNBR:    |      33 |       |      OK |
LOC:          |      86 |       |      OK |
metrics are OK
G_gui (Begins at: 1756 Ends at: 1785)
CalledNBR:    |       8 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
G_tcltk (Begins at: 1788 Ends at: 1803)
LOC:          |      16 |       |      OK |
metrics are OK
show_options (Begins at: 1805 Ends at: 1834)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
show (Begins at: 1836 Ends at: 1849)
CalledNBR:    |       3 |       |      OK |
LOC:          |      14 |       |      OK |
metrics are OK
set_flag (Begins at: 1851 Ends at: 1878)
LOC:          |      28 |       |      OK |
metrics are OK
contains (Begins at: 1883 Ends at: 1892)
LOC:          |      10 |       |      OK |
metrics are OK
set_option (Begins at: 1894 Ends at: 1954)
CalledNBR:    |      13 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
check_opts (Begins at: 1956 Ends at: 1993)
LOC:          |      38 |       |      OK |
metrics are OK
check_an_opt (Begins at: 1995 Ends at: 2037)
ParamNBR:     |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
check_int (Begins at: 2039 Ends at: 2105)
Complexity:   |      13 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      67 |       |      OK |
metrics are OK
check_double (Begins at: 2107 Ends at: 2147)
LOC:          |      41 |       |      OK |
metrics are OK
check_string (Begins at: 2149 Ends at: 2176)
Complexity:   |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
check_required (Begins at: 2178 Ends at: 2201)
LOC:          |      24 |       |      OK |
metrics are OK
split_opts (Begins at: 2203 Ends at: 2266)
LOC:          |      64 |       |      OK |
metrics are OK
check_multiple_opts (Begins at: 2268 Ends at: 2306)
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
check_overwrite (Begins at: 2309 Ends at: 2365)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      11 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
interactive (Begins at: 2367 Ends at: 2395)
LOC:          |      29 |       |      OK |
metrics are OK
interactive_flag (Begins at: 2397 Ends at: 2405)
LOC:          |       9 |       |      OK |
metrics are OK
interactive_option (Begins at: 2407 Ends at: 2497)
Complexity:   |      23 |     * |         |
CalledNBR:    |      41 |     * |         |
LOC:          |      91 |       |      OK |
metrics are OK
split_gisprompt (Begins at: 2499 Ends at: 2529)
LOC:          |      31 |       |      OK |
metrics are OK
gis_prompt (Begins at: 2531 Ends at: 2588)
CalledNBR:    |      20 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
G_recreate_command (Begins at: 2590 Ends at: 2692)
CalledNBR:    |      25 |       |      OK |
LOC:          |     103 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  interactive_flag
In lib/gis/parser.c clones of  interactive_flag are:
	lib/gis/rm_colr.c  G_remove_colr
Threshold GRASS6 key metrics values at 2007-03-07 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
