[GRASS-QA] GRASS QA: benjamin | ./grass6/gem/tools.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 8 08:25:12 EST 2007
Hello benjamin,
ANALYSIS
gem/tools.c functions
basename (Begins at: 32 Ends at: 64)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 33 | | OK |
metrics are OK
mkdir_s (Begins at: 71 Ends at: 77)
Complexity: | 1 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 7 | | OK |
metrics are OK
chop (Begins at: 83 Ends at: 119)
Complexity: | 4 | | OK |
LOC: | 37 | | OK |
metrics are OK
insert_str (Begins at: 121 Ends at: 182)
ParamNBR: | 3 | | OK |
CalledNBR: | 19 | | OK |
LOC: | 62 | | OK |
metrics are OK
delete_str (Begins at: 184 Ends at: 220)
Complexity: | 5 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 37 | | OK |
metrics are OK
find_pos (Begins at: 222 Ends at: 242)
LOC: | 21 | | OK |
metrics are OK
dump_str (Begins at: 249 Ends at: 257)
Complexity: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
get_package_name (Begins at: 263 Ends at: 291)
Complexity: | 3 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 29 | | OK |
metrics are OK
nc_fgets (Begins at: 293 Ends at: 317)
LOC: | 25 | | OK |
metrics are OK
nc_fgets_html (Begins at: 323 Ends at: 448)
Complexity: | 22 | * | |
LOC: | 126 | * | |
metrics are OK
is_text (Begins at: 455 Ends at: 473)
LOC: | 19 | | OK |
metrics are OK
nc_fgets_nb (Begins at: 480 Ends at: 510)
CalledNBR: | 10 | | OK |
LOC: | 31 | | OK |
metrics are OK
dump_ascii (Begins at: 517 Ends at: 532)
CalledNBR: | 7 | | OK |
LOC: | 16 | | OK |
metrics are OK
dump_plain (Begins at: 539 Ends at: 564)
CalledNBR: | 12 | | OK |
LOC: | 26 | | OK |
metrics are OK
dump_html (Begins at: 571 Ends at: 605)
CalledNBR: | 17 | | OK |
LOC: | 35 | | OK |
metrics are OK
list_binaries (Begins at: 613 Ends at: 653)
CalledNBR: | 14 | | OK |
LOC: | 41 | | OK |
metrics are OK
binaries_exist (Begins at: 660 Ends at: 705)
Complexity: | 6 | | OK |
LOC: | 46 | | OK |
metrics are OK
check_filetype (Begins at: 707 Ends at: 729)
CalledNBR: | 6 | | OK |
LOC: | 23 | | OK |
metrics are OK
wget_extension (Begins at: 735 Ends at: 755)
LOC: | 21 | | OK |
metrics are OK
su (Begins at: 762 Ends at: 793)
LOC: | 32 | | OK |
metrics are OK
vercmp (Begins at: 795 Ends at: 819)
Complexity: | 8 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 0 | | OK |
LOC: | 25 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-08 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
