[GRASS-QA] GRASS QA: martinl | ./grass6/raster/r.cats/main.c |no clones | 0 monsters | 0 warnings
Thu Mar 8 09:00:50 EST 2007
Hello martinl,
ANALYSIS
raster/r.cats/main.c functions
main (Begins at: 30 Ends at: 151)
Complexity:   |      16 |     * |         |
CalledNBR:    |      43 |     * |         |
LOC:          |     122 |     * |         |
metrics are OK
print_label (Begins at: 154 Ends at: 162)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
print_d_label (Begins at: 165 Ends at: 177)
CalledNBR:    |       5 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
scan_cats (Begins at: 180 Ends at: 194)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
scan_vals (Begins at: 197 Ends at: 204)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
