[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.to.rast/main.c |no clones | 0 monsters | 0 warnings
Thu Mar 8 16:47:11 EST 2007
Hello martinl,
ANALYSIS
vector/v.to.rast/main.c functions
main (Begins at: 26 Ends at: 146)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      38 |     * |         |
LOC:          |     121 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-08 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
