[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.report/main.c |no
	clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sat Mar 10 03:51:02 EST 2007
Hello markus,
ANALYSIS
raster/r.report/main.c functions
main (Begins at: 20 Ends at: 40)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
