[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.li/r.li.patchdensity/main.c |1 clones (
draw2.c main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 10 03:51:00 EST 2007
Hello markus,
ANALYSIS
raster/r.li/r.li.patchdensity/main.c functions
main (Begins at: 23 Ends at: 52)
Complexity: | 2 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 30 | | OK |
metrics are OK
patch_density (Begins at: 55 Ends at: 199)
Complexity: | 23 | * | |
ParamNBR: | 4 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 145 | * | |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
main
In raster/r.li/r.li.patchdensity/main.c clones of main are:
raster/r.li/r.li.mpa/mpa.c main
raster/r.li/r.li.shape/main.c main
Threshold GRASS6 key metrics values at 2007-03-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
