[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.statistics/o_sdev.c |1 clones ( o_kurt.c o_sdev.c )| 0 monsters | 0 warnings
Sat Mar 10 04:21:42 EST 2007
Hello brad,
ANALYSIS
raster/r.statistics/o_sdev.c functions
o_sdev (Begins at: 16 Ends at: 96)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      81 |       |      OK |
metrics are OK
s_dev (Begins at: 99 Ends at: 132)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      34 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  o_sdev
In raster/r.statistics/o_sdev.c clones of  o_sdev are:
	raster/r.statistics/o_var.c  o_var
Threshold GRASS6 key metrics values at 2007-03-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
