[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.statistics/o_var.c |1
clones ( o_kurt.c o_sdev.c o_skew.c o_var.c )| 0 monsters | 0
warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 10 04:21:43 EST 2007
Hello brad,
ANALYSIS
raster/r.statistics/o_var.c functions
o_var (Begins at: 16 Ends at: 96)
Complexity: | 7 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 16 | | OK |
LOC: | 81 | | OK |
metrics are OK
m_var (Begins at: 99 Ends at: 130)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 32 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
o_var
In raster/r.statistics/o_var.c clones of o_var are:
raster/r.statistics/o_sdev.c o_sdev
Threshold GRASS6 key metrics values at 2007-03-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
