[GRASS-QA] GRASS QA: jachym | ./grass6/general/g.region/cmd/main.c |2 clones ( o_kurt.c o_sdev.c o_skew.c o_var.c draw2.c draw2.c main.c main.c )| 3 monsters | 0 warnings
Sat Mar 10 04:21:44 EST 2007
Hello jachym,
ANALYSIS
general/g.region/cmd/main.c functions
main (Begins at: 28 Ends at: 865)
Complexity:   |     115 |   *** | MONSTER |
CalledNBR:    |     247 |   *** | MONSTER |
LOC:          |     838 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 867 Ends at: 873)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
nsew (Begins at: 875 Ends at: 881)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 883 Ends at: 891)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  llinfo  nsew
In general/g.region/cmd/main.c clones of  llinfo are:
	raster/r.region/main.c  llinfo
In general/g.region/cmd/main.c clones of  nsew are:
	raster/r.region/main.c  nsew
Threshold GRASS6 key metrics values at 2007-03-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
