[GRASS-QA] GRASS QA: glynn | ./grass6/lib/display/draw2.c |2 clones
( o_kurt.c o_sdev.c o_skew.c o_var.c draw2.c draw2.c )| 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 10 04:21:43 EST 2007
Hello glynn,
ANALYSIS
lib/display/draw2.c functions
alloc_int (Begins at: 78 Ends at: 87)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 10 | | OK |
metrics are OK
alloc_float (Begins at: 89 Ends at: 98)
LOC: | 10 | | OK |
metrics are OK
dealloc_float (Begins at: 100 Ends at: 115)
ParamNBR: | 3 | | OK |
LOC: | 16 | | OK |
metrics are OK
do_convert (Begins at: 117 Ends at: 128)
Complexity: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 12 | | OK |
metrics are OK
dist_plane (Begins at: 130 Ends at: 133)
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
interpolate (Begins at: 135 Ends at: 138)
ParamNBR: | 4 | | OK |
LOC: | 4 | | OK |
metrics are OK
clip_plane (Begins at: 140 Ends at: 172)
Complexity: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 33 | | OK |
metrics are OK
do_clip (Begins at: 174 Ends at: 197)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 24 | | OK |
metrics are OK
shift_count (Begins at: 199 Ends at: 202)
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
shift_angle (Begins at: 204 Ends at: 207)
LOC: | 4 | | OK |
metrics are OK
coerce (Begins at: 209 Ends at: 215)
LOC: | 7 | | OK |
metrics are OK
euclidify (Begins at: 217 Ends at: 259)
Complexity: | 3 | | OK |
LOC: | 43 | | OK |
metrics are OK
D_set_clip (Begins at: 261 Ends at: 283)
LOC: | 23 | | OK |
metrics are OK
D_clip_to_map (Begins at: 285 Ends at: 302)
LOC: | 18 | | OK |
metrics are OK
D_move_clip (Begins at: 304 Ends at: 323)
LOC: | 20 | | OK |
metrics are OK
line_clip (Begins at: 325 Ends at: 350)
CalledNBR: | 11 | | OK |
LOC: | 26 | | OK |
metrics are OK
line_clip_ll (Begins at: 352 Ends at: 374)
LOC: | 23 | | OK |
metrics are OK
D_cont_clip (Begins at: 376 Ends at: 392)
LOC: | 17 | | OK |
metrics are OK
D_polydots_clip (Begins at: 394 Ends at: 425)
Complexity: | 5 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 32 | | OK |
metrics are OK
polyline_clip (Begins at: 427 Ends at: 433)
LOC: | 7 | | OK |
metrics are OK
polyline_clip_ll (Begins at: 435 Ends at: 454)
LOC: | 20 | | OK |
metrics are OK
D_polyline_clip (Begins at: 456 Ends at: 468)
LOC: | 13 | | OK |
metrics are OK
clip_polygon_plane (Begins at: 470 Ends at: 510)
LOC: | 41 | | OK |
metrics are OK
polygon_clip (Begins at: 512 Ends at: 539)
LOC: | 28 | | OK |
metrics are OK
polygon_clip_ll (Begins at: 541 Ends at: 561)
LOC: | 21 | | OK |
metrics are OK
D_polygon_clip (Begins at: 563 Ends at: 572)
LOC: | 10 | | OK |
metrics are OK
box_clip (Begins at: 574 Ends at: 590)
CalledNBR: | 9 | | OK |
LOC: | 17 | | OK |
metrics are OK
box_clip_ll (Begins at: 592 Ends at: 605)
LOC: | 14 | | OK |
metrics are OK
D_box_clip (Begins at: 607 Ends at: 616)
LOC: | 10 | | OK |
metrics are OK
D_move (Begins at: 618 Ends at: 624)
LOC: | 7 | | OK |
metrics are OK
D_cont (Begins at: 626 Ends at: 632)
LOC: | 7 | | OK |
metrics are OK
D_polydots (Begins at: 634 Ends at: 638)
LOC: | 5 | | OK |
metrics are OK
D_polyline (Begins at: 640 Ends at: 644)
LOC: | 5 | | OK |
metrics are OK
D_polygon (Begins at: 646 Ends at: 650)
LOC: | 5 | | OK |
metrics are OK
D_box (Begins at: 652 Ends at: 664)
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
D_cont D_move
In lib/display/draw2.c clones of D_move are:
lib/display/draw2.c D_cont
In lib/display/draw2.c clones of D_cont are:
lib/display/draw2.c D_move
Threshold GRASS6 key metrics values at 2007-03-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
