[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.out.mpeg/main.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 10 04:21:45 EST 2007
Hello markus,
ANALYSIS
raster/r.out.mpeg/main.c functions
main (Begins at: 73 Ends at: 151)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 79 | | OK |
metrics are OK
load_files (Begins at: 154 Ends at: 304)
Complexity: | 15 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 46 | * | |
LOC: | 151 | * | |
metrics are OK
use_r_out (Begins at: 307 Ends at: 325)
Complexity: | 3 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 19 | | OK |
metrics are OK
gee_wildfiles (Begins at: 329 Ends at: 381)
Complexity: | 8 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 20 | | OK |
LOC: | 53 | | OK |
metrics are OK
parse_command (Begins at: 385 Ends at: 486)
Complexity: | 9 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 27 | | OK |
LOC: | 102 | | OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
