[GRASS-QA] GRASS QA: markus |
./grass6/raster/r.watershed/front/main.c |no clones | 2
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 10 04:21:47 EST 2007
Hello markus,
ANALYSIS
raster/r.watershed/front/main.c functions
main (Begins at: 22 Ends at: 355)
Complexity: | 29 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 134 | *** | MONSTER |
LOC: | 334 | *** | MONSTER |
2 metric are OUT OF RANGE!
write_hist (Begins at: 358 Ends at: 372)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 15 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
