[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.statistics/main.c |no clones | 0 monsters | 1 warnings
Sat Mar 10 04:21:41 EST 2007
Hello brad,
ANALYSIS
raster/r.statistics/main.c functions
main (Begins at: 14 Ends at: 158)
Complexity:   |      25 |     * |         |
CalledNBR:    |      65 |    ** | Warning |
LOC:          |     145 |     * |         |
at least 1 values are close to an outlier please consider revising code
is_ok (Begins at: 161 Ends at: 167)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
