[GRASS-QA] GRASS QA: brad | ./grass6/raster/r.statistics/o_distrib.c |no clones | 0 monsters | 0 warnings
Sat Mar 10 04:21:42 EST 2007
Hello brad,
ANALYSIS
raster/r.statistics/o_distrib.c functions
o_distrib (Begins at: 14 Ends at: 94)
Complexity:   |       9 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      81 |       |      OK |
metrics are OK
o_out (Begins at: 98 Ends at: 104)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-10 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
