[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.in.poly/poly2rast.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Mar 11 18:39:38 EDT 2007
Hello markus,
ANALYSIS
raster/r.in.poly/poly2rast.c functions
poly_to_rast (Begins at: 7 Ends at: 85)
Complexity: | 12 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 79 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-11 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
