[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/strings.c |2 clones ( strings.c )| 0 monsters | 0 warnings
Mon Mar 12 05:47:42 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/strings.c functions
G_strend (Begins at: 88 Ends at: 105)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
G_strcpy (Begins at: 107 Ends at: 129)
LOC:          |      23 |       |      OK |
metrics are OK
G_chrcpy (Begins at: 131 Ends at: 155)
ParamNBR:     |       3 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
G_strncpy (Begins at: 157 Ends at: 176)
LOC:          |      20 |       |      OK |
metrics are OK
G_strmov (Begins at: 178 Ends at: 200)
LOC:          |      23 |       |      OK |
metrics are OK
G_chrmov (Begins at: 202 Ends at: 224)
LOC:          |      23 |       |      OK |
metrics are OK
G_strcat (Begins at: 226 Ends at: 247)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
G_chrcat (Begins at: 249 Ends at: 267)
LOC:          |      19 |       |      OK |
metrics are OK
G_strcasecmp (Begins at: 269 Ends at: 304)
Complexity:   |      10 |       |      OK |
LOC:          |      36 |       |      OK |
metrics are OK
G_strstr (Begins at: 306 Ends at: 340)
Complexity:   |       4 |       |      OK |
LOC:          |      35 |       |      OK |
metrics are OK
G_strdup (Begins at: 342 Ends at: 364)
CalledNBR:    |       3 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
G_strchg (Begins at: 366 Ends at: 394)
Complexity:   |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
G_str_replace (Begins at: 396 Ends at: 470)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      75 |       |      OK |
metrics are OK
G_strip (Begins at: 472 Ends at: 515)
LOC:          |      44 |       |      OK |
metrics are OK
G_chop (Begins at: 517 Ends at: 549)
Complexity:   |       5 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
G_str_to_upper (Begins at: 551 Ends at: 569)
CalledNBR:    |       1 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
G_str_to_lower (Begins at: 571 Ends at: 591)
LOC:          |      21 |       |      OK |
metrics are OK
G_str_to_sql (Begins at: 593 Ends at: 615)
LOC:          |      23 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  G_strncpy  G_chrcpy
In lib/gis/strings.c clones of  G_chrcpy are:
	lib/gis/strings.c  G_strncpy
In lib/gis/strings.c clones of  G_strncpy are:
	lib/gis/strings.c  G_chrcpy
Threshold GRASS6 key metrics values at 2007-03-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
