[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/strings.c |2 clones
( strings.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Mar 12 06:58:52 EDT 2007
Hello martinl,
ANALYSIS
lib/gis/strings.c functions
G_strend (Begins at: 88 Ends at: 105)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
G_strcpy (Begins at: 107 Ends at: 129)
ParamNBR: | 2 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_chrcpy (Begins at: 131 Ends at: 155)
ParamNBR: | 3 | | OK |
LOC: | 25 | | OK |
metrics are OK
G_strncpy (Begins at: 157 Ends at: 176)
LOC: | 20 | | OK |
metrics are OK
G_strmov (Begins at: 178 Ends at: 200)
LOC: | 23 | | OK |
metrics are OK
G_chrmov (Begins at: 202 Ends at: 224)
LOC: | 23 | | OK |
metrics are OK
G_strcat (Begins at: 226 Ends at: 247)
Complexity: | 1 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 22 | | OK |
metrics are OK
G_chrcat (Begins at: 249 Ends at: 267)
LOC: | 19 | | OK |
metrics are OK
G_strcasecmp (Begins at: 269 Ends at: 304)
Complexity: | 10 | | OK |
LOC: | 36 | | OK |
metrics are OK
G_strstr (Begins at: 306 Ends at: 340)
Complexity: | 4 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_strdup (Begins at: 342 Ends at: 364)
CalledNBR: | 3 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_strchg (Begins at: 366 Ends at: 394)
Complexity: | 3 | | OK |
LOC: | 29 | | OK |
metrics are OK
G_str_replace (Begins at: 396 Ends at: 470)
Complexity: | 11 | | OK |
CalledNBR: | 14 | | OK |
LOC: | 75 | | OK |
metrics are OK
G_strip (Begins at: 472 Ends at: 515)
LOC: | 44 | | OK |
metrics are OK
G_chop (Begins at: 517 Ends at: 549)
Complexity: | 5 | | OK |
LOC: | 33 | | OK |
metrics are OK
G_str_to_upper (Begins at: 551 Ends at: 569)
CalledNBR: | 1 | | OK |
LOC: | 19 | | OK |
metrics are OK
G_str_to_lower (Begins at: 571 Ends at: 591)
LOC: | 21 | | OK |
metrics are OK
G_str_to_sql (Begins at: 593 Ends at: 621)
LOC: | 29 | | OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
G_strncpy G_chrcpy
In lib/gis/strings.c clones of G_chrcpy are:
lib/gis/strings.c G_strncpy
In lib/gis/strings.c clones of G_strncpy are:
lib/gis/strings.c G_chrcpy
Threshold GRASS6 key metrics values at 2007-03-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
