[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.out.ppm/main.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Mar 12 10:15:23 EDT 2007
Hello glynn,
ANALYSIS
raster/r.out.ppm/main.c functions
main (Begins at: 21 Ends at: 248)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 84 | ** | Warning |
LOC: | 228 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
