[GRASS-QA] GRASS QA: hamish |
./grass6/lib/vector/Vlib/legal_vname.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Mar 12 17:30:36 EDT 2007
Hello hamish,
ANALYSIS
lib/vector/Vlib/legal_vname.c functions
Vect_legal_filename (Begins at: 16 Ends at: 52)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 37 | | OK |
metrics are OK
Vect_check_input_output_name (Begins at: 54 Ends at: 104)
Complexity: | 12 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 51 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-12 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 271 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
