[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.random.surface/save.c |no clones | 0 monsters | 1 warnings
Mon Mar 12 18:40:56 EDT 2007
Hello markus,
ANALYSIS
raster/r.random.surface/save.c functions
SaveMap (Begins at: 13 Ends at: 223)
Complexity:   |      22 |     * |         |
CalledNBR:    |      27 |       |      OK |
LOC:          |     211 |    ** | Warning |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-12 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     271 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
