[GRASS-QA] GRASS QA: martin | ./grass6/raster/r.resamp.stats/main.c
|1 clones ( main.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 13 04:59:13 EDT 2007
Hello martin,
ANALYSIS
raster/r.resamp.stats/main.c functions
build_method_list (Begins at: 43 Ends at: 60)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 18 | | OK |
metrics are OK
find_method (Begins at: 62 Ends at: 71)
LOC: | 10 | | OK |
metrics are OK
resamp_unweighted (Begins at: 81 Ends at: 153)
Complexity: | 3 | | OK |
CalledNBR: | 18 | | OK |
LOC: | 73 | | OK |
metrics are OK
resamp_weighted (Begins at: 155 Ends at: 244)
CalledNBR: | 20 | | OK |
LOC: | 90 | | OK |
metrics are OK
main (Begins at: 246 Ends at: 385)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 68 | ** | Warning |
LOC: | 140 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file has 1 potentially cloned functions:
build_method_list
In raster/r.resamp.stats/main.c clones of build_method_list are:
raster/r.series/main.c build_method_list
Threshold GRASS6 key metrics values at 2007-03-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
