[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.to.rast/do_lines.c
|no clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 13 08:37:34 EDT 2007
Hello martinl,
ANALYSIS
vector/v.to.rast/do_lines.c functions
do_lines (Begins at: 16 Ends at: 114)
Complexity: | 23 | * | |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 24 | | OK |
LOC: | 99 | | OK |
1 metric are OUT OF RANGE!
plot_line (Begins at: 117 Ends at: 130)
Complexity: | 3 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
v2angle (Begins at: 135 Ends at: 140)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
deg_angle (Begins at: 144 Ends at: 162)
Complexity: | 2 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
plot_points (Begins at: 165 Ends at: 171)
ParamNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-13 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
