[GRASS-QA] GRASS QA: martinl | ./grass6/vector/lidar/v.outlier/main.c |no clones | 2 monsters | 0 warnings
Tue Mar 13 16:36:37 EDT 2007
Hello martinl,
ANALYSIS
vector/lidar/v.outlier/main.c functions
main (Begins at: 37 Ends at: 339)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |     118 |   *** | MONSTER |
LOC:          |     303 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-13 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
