[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.extrude/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Mar 14 05:30:19 EDT 2007
Hello martinl,
ANALYSIS
vector/v.extrude/main.c functions
main (Begins at: 37 Ends at: 342)
Complexity: | 35 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 110 | *** | MONSTER |
LOC: | 306 | *** | MONSTER |
2 metric are OUT OF RANGE!
extrude (Begins at: 348 Ends at: 434)
Complexity: | 7 | | OK |
ParamNBR: | 10 | *** | MONSTER |
CalledNBR: | 13 | | OK |
LOC: | 87 | | OK |
1 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
