[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.convert/read.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Mar 14 05:30:18 EDT 2007
Hello martinl,
ANALYSIS
vector/v.convert/read.c functions
read_dig (Begins at: 15 Ends at: 177)
Complexity: | 30 | ** | Warning |
ParamNBR: | 5 | * | |
CalledNBR: | 69 | ** | Warning |
LOC: | 163 | * | |
at least 2 values are close to an outlier please consider revising code
read_line (Begins at: 182 Ends at: 200)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 19 | | OK |
metrics are OK
read_att (Begins at: 203 Ends at: 272)
Complexity: | 13 | | OK |
CalledNBR: | 25 | | OK |
LOC: | 70 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
