[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.kcv/histo.c |no clones | 0 monsters | 0 warnings
Thu Mar 15 04:49:08 EDT 2007
Hello martinl,
ANALYSIS
vector/v.kcv/histo.c functions
make_histo (Begins at: 13 Ends at: 32)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
