[GRASS-QA] GRASS QA: markus | ./grass6/lib/vector/Vlib/header.c |no clones | 0 monsters | 0 warnings
Thu Mar 15 06:46:23 EDT 2007
Hello markus,
ANALYSIS
lib/vector/Vlib/header.c functions
Vect_print_header (Begins at: 35 Ends at: 51)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       9 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
Vect_read_header (Begins at: 54 Ends at: 65)
CalledNBR:    |       1 |       |      OK |
LOC:          |      12 |       |      OK |
metrics are OK
Vect_write_header (Begins at: 68 Ends at: 73)
LOC:          |       6 |       |      OK |
metrics are OK
Vect__write_head (Begins at: 81 Ends at: 107)
Complexity:   |       2 |       |      OK |
CalledNBR:    |      22 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
Vect__read_head (Begins at: 114 Ends at: 187)
Complexity:   |      18 |     * |         |
CalledNBR:    |      44 |     * |         |
LOC:          |      74 |       |      OK |
metrics are OK
Vect_get_name (Begins at: 190 Ends at: 193)
CalledNBR:    |       0 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
Vect_get_mapset (Begins at: 202 Ends at: 205)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_get_full_name (Begins at: 214 Ends at: 221)
CalledNBR:    |       4 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Vect_is_3d (Begins at: 230 Ends at: 233)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_organization (Begins at: 242 Ends at: 247)
CalledNBR:    |       2 |       |      OK |
LOC:          |       6 |       |      OK |
metrics are OK
Vect_get_organization (Begins at: 256 Ends at: 266)
LOC:          |      11 |       |      OK |
metrics are OK
Vect_set_date (Begins at: 269 Ends at: 281)
LOC:          |      13 |       |      OK |
metrics are OK
Vect_get_date (Begins at: 284 Ends at: 287)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_person (Begins at: 296 Ends at: 301)
LOC:          |       6 |       |      OK |
metrics are OK
Vect_get_person (Begins at: 310 Ends at: 313)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_map_name (Begins at: 322 Ends at: 327)
LOC:          |       6 |       |      OK |
metrics are OK
Vect_get_map_name (Begins at: 336 Ends at: 339)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_map_date (Begins at: 348 Ends at: 353)
LOC:          |       6 |       |      OK |
metrics are OK
Vect_get_map_date (Begins at: 362 Ends at: 365)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_scale (Begins at: 374 Ends at: 378)
LOC:          |       5 |       |      OK |
metrics are OK
Vect_get_scale (Begins at: 387 Ends at: 390)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_comment (Begins at: 399 Ends at: 404)
LOC:          |       6 |       |      OK |
metrics are OK
Vect_get_comment (Begins at: 413 Ends at: 416)
LOC:          |       4 |       |      OK |
metrics are OK
Vect_set_zone (Begins at: 425 Ends at: 436)
LOC:          |      12 |       |      OK |
metrics are OK
Vect_get_zone (Begins at: 439 Ends at: 452)
LOC:          |      14 |       |      OK |
metrics are OK
Vect_get_proj (Begins at: 455 Ends at: 471)
LOC:          |      17 |       |      OK |
metrics are OK
Vect_get_proj_name (Begins at: 473 Ends at: 497)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Vect_set_thresh (Begins at: 500 Ends at: 505)
LOC:          |       6 |       |      OK |
metrics are OK
Vect_get_thresh (Begins at: 514 Ends at: 518)
LOC:          |       5 |       |      OK |
metrics are OK
lookup (Begins at: 522 Ends at: 528)
ParamNBR:     |       4 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-15 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
