[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/intersect.c
|no clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 15 09:35:33 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/intersect.c functions
Vect_segment_intersection (Begins at: 128 Ends at: 375)
Complexity: | 41 | *** | MONSTER |
ParamNBR: | 19 | *** | MONSTER |
CalledNBR: | 43 | * | |
LOC: | 248 | ** | Warning |
2 metric are OUT OF RANGE!
add_cross (Begins at: 392 Ends at: 410)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 3 | | OK |
LOC: | 19 | | OK |
metrics are OK
cmp_cross (Begins at: 412 Ends at: 423)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
dist2 (Begins at: 425 Ends at: 444)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 20 | | OK |
metrics are OK
cross_seg (Begins at: 449 Ends at: 511)
Complexity: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 63 | | OK |
metrics are OK
Vect_line_intersection (Begins at: 514 Ends at: 919)
Complexity: | 31 | ** | Warning |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 45 | * | |
LOC: | 406 | *** | MONSTER |
1 metric are OUT OF RANGE!
find_cross (Begins at: 926 Ends at: 964)
CalledNBR: | 1 | | OK |
LOC: | 39 | | OK |
metrics are OK
Vect_line_check_intersection (Begins at: 967 Ends at: 1083)
Complexity: | 16 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 117 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
