[GRASS-QA] GRASS QA: martinl | ./grass6/lib/vector/Vlib/find.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 15 10:14:10 EDT 2007
Hello martinl,
ANALYSIS
lib/vector/Vlib/find.c functions
Vect_find_node (Begins at: 59 Ends at: 126)
Complexity: | 5 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 9 | | OK |
LOC: | 68 | | OK |
metrics are OK
Vect_find_line (Begins at: 129 Ends at: 215)
Complexity: | 7 | | OK |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 10 | | OK |
LOC: | 87 | | OK |
at least 1 values are close to an outlier please consider revising code
Vect_find_area (Begins at: 218 Ends at: 260)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 43 | | OK |
metrics are OK
Vect_find_island (Begins at: 263 Ends at: 312)
Complexity: | 6 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 50 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
