[GRASS-QA] GRASS QA: glynn | ./grass6/display/d.what.vect/what.c
|no clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Mar 15 16:17:10 EDT 2007
Hello glynn,
ANALYSIS
display/d.what.vect/what.c functions
what (Begins at: 18 Ends at: 423)
Complexity: | 76 | *** | MONSTER |
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 176 | *** | MONSTER |
LOC: | 406 | *** | MONSTER |
3 metric are OUT OF RANGE!
show_buttons (Begins at: 426 Ends at: 446)
Complexity: | 4 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 21 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-15 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
