[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/select.c |no clones | 0 monsters | 0 warnings
Fri Mar 16 14:40:46 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/select.c functions
select_lines (Begins at: 23 Ends at: 55)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      33 |       |      OK |
metrics are OK
do_print_selected (Begins at: 58 Ends at: 82)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
sel_by_cat (Begins at: 88 Ends at: 110)
Complexity:   |       1 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
sel_by_coordinates (Begins at: 116 Ends at: 139)
Complexity:   |       2 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
sel_by_bbox (Begins at: 145 Ends at: 171)
CalledNBR:    |       7 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
sel_by_polygon (Begins at: 177 Ends at: 199)
CalledNBR:    |      12 |       |      OK |
LOC:          |      23 |       |      OK |
metrics are OK
sel_by_id (Begins at: 205 Ends at: 226)
CalledNBR:    |       5 |       |      OK |
LOC:          |      22 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-16 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
