[GRASS-QA] GRASS QA: markus | ./grass6/db/drivers/sqlite/describe.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 17 18:42:02 EDT 2007
Hello markus,
ANALYSIS
db/drivers/sqlite/describe.c functions
db__driver_describe_table (Begins at: 21 Ends at: 62)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 21 | | OK |
LOC: | 42 | | OK |
metrics are OK
describe_table (Begins at: 65 Ends at: 181)
Complexity: | 6 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 117 | | OK |
metrics are OK
get_column_info (Begins at: 183 Ends at: 243)
Complexity: | 8 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 61 | | OK |
metrics are OK
affinity_type (Begins at: 245 Ends at: 268)
Complexity: | 4 | | OK |
ParamNBR: | 1 | | OK |
LOC: | 24 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-17 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
