[GRASS-QA] GRASS QA: glynn | ./grass6/db/drivers/sqlite/describe.c
	|no clones | 0 monsters | 0 warnings
    grass-qa at proxy.soccerlab.polymtl.ca
    Sat Mar 17 20:15:23 EDT 2007
Hello glynn,
ANALYSIS
db/drivers/sqlite/describe.c functions
db__driver_describe_table (Begins at: 21 Ends at: 62)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      42 |       |      OK |
metrics are OK
describe_table (Begins at: 65 Ends at: 181)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |     117 |       |      OK |
metrics are OK
get_column_info (Begins at: 183 Ends at: 239)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      57 |       |      OK |
metrics are OK
affinity_type (Begins at: 241 Ends at: 264)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-17 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
