[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.sample/main.c |no clones | 1 monsters | 0 warnings
Tue Mar 20 03:17:53 EDT 2007
Hello markus,
ANALYSIS
vector/v.sample/main.c functions
main (Begins at: 51 Ends at: 304)
Complexity:   |      24 |     * |         |
CalledNBR:    |     109 |   *** | MONSTER |
LOC:          |     254 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
