[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.surf.idw/main.c |no
clones | 0 monsters | 3 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Mar 20 13:36:42 EDT 2007
Hello markus,
ANALYSIS
raster/r.surf.idw/main.c functions
main (Begins at: 28 Ends at: 158)
Complexity: | 12 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 53 | * | |
LOC: | 131 | * | |
metrics are OK
lookup_and_function_ptrs (Begins at: 160 Ends at: 193)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 34 | | OK |
metrics are OK
interpolate (Begins at: 196 Ends at: 284)
Complexity: | 7 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 11 | | OK |
LOC: | 89 | | OK |
at least 1 values are close to an outlier please consider revising code
make_neighbors_list (Begins at: 286 Ends at: 349)
Complexity: | 11 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 64 | | OK |
search (Begins at: 354 Ends at: 400)
ParamNBR: | 8 | ** | Warning |
CalledNBR: | 8 | | OK |
LOC: | 47 | | OK |
exhaust (Begins at: 403 Ends at: 429)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 27 | | OK |
metrics are OK
offset_distance (Begins at: 431 Ends at: 434)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 4 | | OK |
metrics are OK
completed_row (Begins at: 440 Ends at: 443)
LOC: | 4 | | OK |
metrics are OK
next_row (Begins at: 446 Ends at: 461)
Complexity: | 4 | | OK |
LOC: | 16 | | OK |
metrics are OK
first_west (Begins at: 469 Ends at: 483)
Complexity: | 3 | | OK |
LOC: | 15 | | OK |
metrics are OK
find_neighbors (Begins at: 491 Ends at: 519)
ParamNBR: | 6 | * | |
CalledNBR: | 3 | | OK |
LOC: | 29 | | OK |
metrics are OK
exhaust_search (Begins at: 526 Ends at: 548)
LOC: | 23 | | OK |
metrics are OK
triangulate (Begins at: 555 Ends at: 563)
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
add_neighbor (Begins at: 566 Ends at: 581)
LOC: | 16 | | OK |
metrics are OK
replace_neighbor (Begins at: 584 Ends at: 606)
CalledNBR: | 1 | | OK |
LOC: | 23 | | OK |
metrics are OK
sort_neighbors (Begins at: 609 Ends at: 622)
LOC: | 14 | | OK |
metrics are OK
free_row_lists (Begins at: 626 Ends at: 643)
LOC: | 18 | | OK |
metrics are OK
row_lists (Begins at: 646 Ends at: 706)
LOC: | 61 | | OK |
metrics are OK
lookup_tables (Begins at: 713 Ends at: 731)
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
