[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.to.rast/support.c |2 clones ( support.c )| 0 monsters | 0 warnings
Tue Mar 20 13:36:42 EDT 2007
Hello markus,
ANALYSIS
vector/v.to.rast/support.c functions
update_hist (Begins at: 12 Ends at: 43)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
update_colors (Begins at: 46 Ends at: 58)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
update_fcolors (Begins at: 62 Ends at: 74)
LOC:          |      13 |       |      OK |
metrics are OK
update_cats (Begins at: 78 Ends at: 90)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  update_fcolors  update_colors
In vector/v.to.rast/support.c clones of  update_colors are:
	vector/v.to.rast/support.c  update_fcolors
In vector/v.to.rast/support.c clones of  update_fcolors are:
	vector/v.to.rast/support.c  update_colors
Threshold GRASS6 key metrics values at 2007-03-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
