[GRASS-QA] GRASS QA: paul | ./grass6/raster/r.coin/make_coin.c |1 clones ( make_coin.c )| 0 monsters | 0 warnings
Tue Mar 20 15:58:12 EDT 2007
Hello paul,
ANALYSIS
raster/r.coin/make_coin.c functions
make_coin (Begins at: 32 Ends at: 190)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      42 |     * |         |
LOC:          |     159 |     * |         |
metrics are OK
cmp (Begins at: 192 Ends at: 201)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
collapse (Begins at: 204 Ends at: 222)
LOC:          |      19 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  cmp
In raster/r.coin/make_coin.c clones of  cmp are:
	raster/r.random.cells/init.c  comp_array
Threshold GRASS6 key metrics values at 2007-03-20 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
