[GRASS-QA] GRASS QA: martinl |
./grass6/vector/v.edit/max_distance.c |no clones | 0 monsters
| 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Mar 21 04:42:07 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/max_distance.c functions
max_distance (Begins at: 28 Ends at: 59)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 32 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-21 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
