[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/cats.c |no clones | 0 monsters | 0 warnings
Wed Mar 21 04:42:07 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/cats.c functions
cats (Begins at: 26 Ends at: 125)
Complexity:   |      15 |       |      OK |
CalledNBR:    |      31 |       |      OK |
LOC:          |     100 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
