[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/args.c |no clones | 0 monsters | 2 warnings
Wed Mar 21 04:48:50 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/args.c functions
parser (Begins at: 3 Ends at: 252)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      60 |     * |         |
LOC:          |     250 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-21 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
