[GRASS-QA] GRASS QA: markus | ./grass6/display/d.vect/topo.c |no clones | 0 monsters | 0 warnings
Thu Mar 22 09:11:44 EDT 2007
Hello markus,
ANALYSIS
display/d.vect/topo.c functions
topo (Begins at: 8 Ends at: 179)
Complexity:   |      22 |     * |         |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      50 |     * |         |
LOC:          |     172 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-03-22 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      86 |
LOC:                    43 |       195 |     272 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
