[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/select.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 24 16:34:54 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/select.c functions
select_lines (Begins at: 24 Ends at: 65)
Complexity: | 7 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 42 | | OK |
metrics are OK
do_print_selected (Begins at: 73 Ends at: 89)
Complexity: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 17 | | OK |
metrics are OK
sel_by_cat (Begins at: 96 Ends at: 145)
Complexity: | 4 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 50 | | OK |
metrics are OK
sel_by_coordinates (Begins at: 152 Ends at: 194)
ParamNBR: | 2 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 43 | | OK |
metrics are OK
sel_by_bbox (Begins at: 201 Ends at: 244)
Complexity: | 3 | | OK |
LOC: | 44 | | OK |
metrics are OK
sel_by_polygon (Begins at: 251 Ends at: 299)
CalledNBR: | 15 | | OK |
LOC: | 49 | | OK |
metrics are OK
sel_by_id (Begins at: 306 Ends at: 349)
CalledNBR: | 9 | | OK |
LOC: | 44 | | OK |
metrics are OK
sel_by_where (Begins at: 356 Ends at: 429)
Complexity: | 8 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 74 | | OK |
metrics are OK
merge_lists (Begins at: 431 Ends at: 449)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 19 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
