[GRASS-QA] GRASS QA: martinl | ./grass6/vector/v.edit/main.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Mar 24 16:34:54 EDT 2007
Hello martinl,
ANALYSIS
vector/v.edit/main.c functions
main (Begins at: 23 Ends at: 156)
Complexity: | 28 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 50 | * | |
LOC: | 134 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2007-03-24 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
