[GRASS-QA] GRASS QA: hamish | ./grass6/vector/v.segment/main.c |1
clones ( main.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Mar 25 23:02:40 EDT 2007
Hello hamish,
ANALYSIS
vector/v.segment/main.c functions
main (Begins at: 27 Ends at: 185)
Complexity: | 15 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 62 | ** | Warning |
LOC: | 159 | * | |
at least 1 values are close to an outlier please consider revising code
find_line (Begins at: 189 Ends at: 206)
Complexity: | 3 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 18 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
find_line
In vector/v.segment/main.c clones of find_line are:
vector/v.lrs/v.lrs.segment/main.c find_line
Threshold GRASS6 key metrics values at 2007-03-25 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 37 |
ParamNBR: 2 | 6 | 9 |
CalledNBR: 10 | 60 | 86 |
LOC: 43 | 195 | 272 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
